Been trying to remove many defects in old records using Audacity.
Seeking suggestions on the fastest way to navigate to the problem spots in the the waveform view, make a quick repair and then quickly find the next location to fix.
Is there an auto-locate pops effect?
Flaws too numerous to use a global effect like click removal or noise reduction, at least with default settings.
Suggestions please.
Wish quickly find and repair clicks and pops in LP waveforms
Mr. Tin Ears
Re: Wish quickly find and repair clicks and pops in LP wavef
There is a load of information about digitizing LPs here; http://manual.audacityteam.org/o/man/sa ... ation.html
Paul-L's DeClicker plugin ... http://forum.audacityteam.org/viewtopic ... 49#p245549Mr. Tin Ears wrote: Seeking suggestions on the fastest way to navigate to the problem spots in the the waveform view, make a quick repair and then quickly find the next location to fix. Is there an auto-locate pops effect?
waxcylinder
I used to do this by hand like you (a very long and arduous task) until Koz steered me in the direction of Brian Davies's ClickRepair. it costs a little around $40 I think but does come with a 14 day free trial. You can either run it manually but I ended up automating the process - but I did soften Brian's default settings a little. It produced truly excellent results for me and I listen on fairly high-end, albeit antique, QUAD ESL-57 electrostatic speakers.
See this sticky thread on the Forum: http://forum.audacityteam.org/viewtopic.php?f=28&t=1994
