There is a 30-band graphic equalizer in the Calf pack that I have. This is it running in Audacity.Gale Andrews wrote:Calf does not have more than a 12-band equalizer
It generally runs ok, but when I close the effect window, Audacity crashes.
I definitely don't have that. Is it a Debian package of Calf or did you compile it from source code?steve wrote:There is a 30-band graphic equalizer in the Calf pack that I have.Gale Andrews wrote:Calf does not have more than a 12-band equalizer
Is that when you use any close method, and if you close when playing audio or not?steve wrote:It generally runs ok, but when I close the effect window, Audacity crashes.
Yes. https://packages.debian.org/jessie/calf-pluginsGale Andrews wrote:Is it a Debian package of Calf
It seems to be by any method with any of the Calf plug-ins, whether playing or stopped.Gale Andrews wrote:Is that when you use any close method,
OK, that's a later package than mine. I presume Ubuntu 15.04 would also have that package.steve wrote:Yes. https://packages.debian.org/jessie/calf-pluginsGale Andrews wrote:Is it a Debian package of Calf
That could be older versions of Calf as well.steve wrote:It seems to be by any method with any of the Calf plug-ins, whether playing or stopped.Gale Andrews wrote:Is that when you use any close method,
When I have time I'll try building from source and see if they then work better. I know that Leland has used Calf plug-ins successfully.
