Audacity setup problem...line not open?
Please state:
Please state:
RAaudacity
I got audacity installed, but it won't record anything except through Pulse rear mic:0.
It won't record on Pulse: line:0 (with stuff playing) or any of the other selections available, just Pulse rear mic:0, as mentioned.
Are the lines closed in Ubuntu and have to be opened in Terminal, or is this something that needs to be changed in Audacity?
How do I fix this?
Thanks
How do I fix this?
Thanks
Re: Audacity setup problem...line not open?
What's the goal? What are you trying to do?
Which version are you using?
RAaudacity
kozikowski wrote:What's the goal? What are you trying to do?
I want to be able to record streaming material. It's v 2.0.5
Try the "PulseAudio" method described here: http://manual.audacityteam.org/o/man/tu ... linux.html
RAaudacity
>Try the "PulseAudio" method described here: http://manual.audacityteam.org/o/man/tu ... linux.html<
No luck.
Here's screenshot of the way Audacity and Gnome ALSA mixer is setup, and with which I can't get any streaming in for recording.
I've tried lots output / input combinations - none work for streaming audio.
See anything that is messed up and needs changing?
http://picpaste.com/Screenshot-konzUQTB.png
No luck.
RAaudacity
I may have solved the problem. The "PulseAudio Volume Control" that I got during a download didn't look like what is pictured in the tutorial you linked - there was no access to the tabs shown.
Just now I uninstalled what I had, re-installed, and got a "PulseAudio Volume Control" that looked like what's in the tutorial.
I changed to "analog stereo output" in the config tab, and started getting recordable input in Audacity.
Thanks
Thanks
- Quality Assurance
The best way to be sure of getting a compatible version of PulseAudio Volume Control for your system is usually to enter the following in a terminal:RAaudacity wrote:I may have solved the problem. The "PulseAudio Volume Control" that I got during a download didn't look like what is pictured in the tutorial you linked - there was no access to the tabs shown.
Code: Select all
sudo apt-get install pavucontrol________________________________________FOR INSTANT HELP: (Click on Link below)
