Turning an audacity file so that it is downloadable
lazyboredom
Post by lazyboredom » Mon Feb 23, 2009 1:43 am
Ya, i have a website and i was wondering how i could put it on there, all i have to do is upload it but when i do it just wont download it will say its on there but even though its not in the website database, nor is playing the music.any advice?
allencmcbride
Re: Turning an audacity file so that it is downloadable
Post by allencmcbride » Mon Feb 23, 2009 3:01 am
Audacity projects (which are collections of files) are not what you would want to put on the web to make available to others. Use Audacity's Export options (in the File menu) to make a .wav, .mp3, or .ogg file and put that on the web instead. If you have an exported audio file and you're still having trouble getting it on the web, you might be better off looking for help in a forum dedicated to the software you're using for your website. --Allen
Post by kozikowski » Mon Feb 23, 2009 3:09 am
Yes, that's the normal problem. Audacity doesn't Save sound files and nobody can download a Project. You have to Export your show into some sound file and then it should work OK. How do you get the work up there? WinFTP? Some FTP software built into your web authoring tools? I think you can post stuff with the FTP system inside FireFox.
http://www.kozco.com/tech/piano2.wav
This is one of mine. It's a straight WAV music file inside the folder "tech" in the main page. I have visible pages pointing to it, but I don't have to do that. I have test sound files up there that if you didn't already know they were there, you'd never figure it out or see them.
