Any presets for bass removal and
Help for Audacity on macOS.
Puu
Post by Puu » Sat Sep 12, 2015 8:27 pm
Hi all, I am a tech novice and most of the names sound like Chinese to me.
Try to find a way to easy remove too much boomy bass. For too much high pinch I use "Fix Clipping", what works for me.
Are there any recommended plugins that auto run for both Bass and high pinch? I looked at a list of plugins - oh boy - non of the names tell em anything.
BTW: Even with my limited knowledge - I like Audacity a lot. Any link where to donate? Live on workmans comp and can"t do much, but hope a few $ support this.
Re: Any presets for bass removal and
Post by kozikowski » Sun Sep 13, 2015 2:27 am
Select the whole show by clicking just above MUTE.
Effect > Bass and Treble...
That's the rough equivalent of the bass and treble controls on your music system plus simple volume.
Post by kozikowski » Sun Sep 13, 2015 2:33 am
http://audacityteam.org/donate/
Puu
Post by Puu » Sun Sep 13, 2015 8:13 am
Tks, done Transaction ID: ************99303
Puu
Post by Puu » Sun Sep 13, 2015 8:18 am
kozikowski wrote:Select the whole show by clicking just above MUTE.
??? do not see any MUTE button, therefore nothing to click above ???
Trebor
Post by Trebor » Sun Sep 13, 2015 12:10 pm
Puu wrote: ??? do not see any MUTE button, therefore nothing to click above ???
Audacity can edit many tracks at once. To select the track you want to apply the effect to,
left-mouse-click on the panel with "Hz" on it, immediately-above the "Mute" & "Solo" buttons .
The selected track goes dark-grey ...
To select track, left mouse-click on panel above 'mute'solo' buttons'.gif (157.28 KiB) Viewed 563 times
Post by Gale Andrews » Sun Sep 13, 2015 6:06 pm
Thank you! :D
Puu
Post by Puu » Fri Sep 18, 2015 5:41 am
Thanks, found MUTE. But clicking above does only act when I click on the triangle and the is a NORMAl and Bandwith but no bass presets
Puu
Trebor
Post by Trebor » Fri Sep 18, 2015 8:25 am
Puu wrote:Thanks, found MUTE. But clicking above does only act when I click on the triangle ...
Clicking on the nearest black triangle shows the drop-down-menu for that track , clicking on the triangle doesn't select the track.
There are other ways to select the track (or part thereof) where you want to apply an effect ,
see ... http://manual.audacityteam.org/o/man/[b ... _selection[/b].html
Puu
Post by Puu » Thu Sep 24, 2015 6:04 am
Thanks, my mistake. Maybe it is my brain or the second language problem, but I Have to admit that I do not get it!
