I opened two mp3 tonight and both opened a diferent instance of audacity instead of one on different tracks. Why is this and how can i get back to having two tracks in one instance? Win 7 764 bit - Audacity 2.1.1
Thanks
JM
Opening two files
jack magee
- Operating System: Windows 7
Re: Opening two files
There might be more than one way to do it, but try dragging the 2nd file in to Audacity.
Every time you File > Import > Audio, you get a new sound track stacked below the last one (click the graphic).
- Attachments
- Screen Shot 2015-09-04 at 21.16.11.png (48.23 KiB) Viewed 228 times
jack magee
Thanks guys I made the mistake of opening instead of import or drag
