I meant for example, try running some effects and see if you can still use the project window afterwards.cmac185 wrote:I'm not sure what you were referring to opening other dialog windows as a test. I don't see any other ones other than the plugin dialog that can be opened from several menu items.
Similarly, try FIle > Edit Metadata..., Audacity > Preferences..., Help > Audio Device Info... and others. The problem may not be confined to the Plug- in Manager.
The cursor being the mouse pointer?cmac185 wrote:In the process of editing a recording last night I noticed another issue.
You can reproduce it by having a recording displayed in the track display. Then click somewhere on the recording with the cursor
Yes, thank you. I can see that. wx Widgets 3 again, I assume, and it affects other toolbars in the upper tooldock area.cmac185 wrote:and notice that you can move the cursor with the arrow keys. Then either zoom in or out using the zoom tools from the tool bar. Now try to move the cursor with the arrow keys. You'll find the cursor will not move anymore. Click somewhere else and now the arrow keys work. Do another zoom and you'll find the arrow keys unresponsive again. This is on both 2.1.2A versions.
I think you will have to use keyboard shortcuts instead.
Not planned, but not unexpected. That is unlikely to be fixed for 2.1.2.cmac185 wrote:A question regarding Tool Tips. I notice that all, but the recording and playback tool tips don't work on 2.1.2 Alpha. Is this planned?
It's also annoying that track focus is temporarily lost while dragging a slider.cmac185 wrote:when hovering over the recording/playback slider when the Tool Tip comes up the focus in Audacity changes so the color goes away in the drop down buttons for things like "Input Source" and the like and the yellow box around the selected track display goes away. You may not have any control over that, but it seems like a whole lot more processing going on that would be necessary just to put up the Tool Tip.
Yes please I was going to suggest starting a new topic or topics if the Sound Activated Crashes are fixed as I think they are.cmac185 wrote:Would you rather use another means to report suspected bugs than this forum thread? I was just thinking the topic is kind of changing.
