Help for Audacity on macOS.
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
Post
by kozikowski » Sun Aug 30, 2015 12:47 am
130 if I ever do want to overdub.
If you want to overdub you have to set it for your machine and sound system combo. 130 is a wild guess. Chances of it working in your machine is zero.
The instructions for setting Recording Latency / Overdubbing.
http://manual.audacityteam.org/o/man/tu ... rdubs.html
Much better to set it for your sound system and microphone and select/de-select Overdub as it's needed.
chrzaszcz
- Operating System: macOS 10.14 Mojave
Post
by chrzaszcz » Sun Aug 30, 2015 11:43 pm
Alright, thank you.
