Audacity E-MU1212m Problem
TheButcher69
Re: Audacity E-MU1212m Problem
Post by TheButcher69 » Sun Sep 06, 2015 3:33 am
I could not get WDM-KS to work at all. Records silence.
I did find out that Reaper wasn't having a problem. It was me not click on the peak meters & selecting "Input: Stereo" "Aux 1 L / Aux 1 R" to get a stereo recording.
I just can't understand code & put your info together to compile Audacity. Maybe in time but I just can't understand it.
Post by Gale Andrews » Sun Sep 06, 2015 6:44 pm
TheButcher69 wrote:I did find out that Reaper wasn't having a problem. It was me not click on the peak meters & selecting "Input: Stereo" "Aux 1 L / Aux 1 R" to get a stereo recording.
Do you still need ASIO to record correctly in Reaper with your maximum memory?
Do you have the 64-bit or 32-bit version of Reaper? Is Reaper recording to RAM or disk?
Audacity is only 32-bit and can address only 2 GB of memory. The Audacity versions you have tried don't have an option to record to RAM.
TheButcher69 wrote:I just can't understand code & put your info together to compile Audacity. Maybe in time but I just can't understand it.
Doing it a step each day or two can be good. Start with installing Visual Studio, which should be familiar enough.
TheButcher69
Post by TheButcher69 » Mon Sep 07, 2015 10:00 pm
I still need to record with ASIO in Reaper
I'm using Reaper 32bit
I'm not sure if Reaper is recording to RAM or disk. I didn't change anything in Reaper except for the sound driver "ASIO"
