Audacity E-MU1212m Problem
TheButcher69
Re: Audacity E-MU1212m Problem
Post by TheButcher69 » Wed Sep 02, 2015 7:31 pm
So I ordered memory from Crucial that they said would work & assured me they could get to work. NOT!
ASUS told me it's the latency. I believe them because the PNY had a 10ms & I could record sound already on computer & playback was fine but with the Crucial CT7348776 it breaks up & the latency is 11ms. On my old Crucial 2gb stick it's 4ms & the new memory is 11ms. Crucial has no idea how to correct the latency in Audacity or Cool Edit 2000. I can only record silence & breakup sound with the new faster memory. So does anyone know how to make Audacity work with the new memory?
It records fine with the old 2gb Crucial memory but with the new memory I get the same problem as with the PNY.
System Specs:
Windows 8.1 64bit
ASUS M4A77T/USB3 motherboard newest BIOS 0801
Newest AMD motherboard Chipset drivers
CPU AMD Phenom II X4 955
Soundcard E-MU1212m newest drivers & newest Patchmix all set & working
Post by Gale Andrews » Thu Sep 03, 2015 2:10 pm
What is the PNY?
Audacity has a setting "Audio to buffer" in Recording Preferences. If E-MU has a buffer setting for example in its control panel, you may need to adjust that setting as well.
Sample rates are important too. Excessive sample rates or rates mismatched between the device, Windows and Audacity can and do cause garbled playback (or speed problems). If using MME host (which is high latency), Default Format in Windows Sound must be set to the same rate as Audacity.
If using lower latency WASAPI, you should be better to turn on Exclusive Mode in Windows Sound. Then the Default Format rate should be ignored. You still have to set the same rate in E-MU, if it can set sample rates.
TheButcher69
Post by TheButcher69 » Thu Sep 03, 2015 5:55 pm
PNY is the other company that I bought memory from. 8GB PC3-12800 & PC3-10666 1333
I did mess with with those settings in Audacity & E-MU does have sample rates which I tried different ones setting both to the same rate but still won't let it record nothing but silence & sometimes stutter. I'm not sure what the E-MU bit rate is but in Windows 8.1 sound it shows 48000 24 bit & I can not change it. I have all windows sounds off. Once in awhile it will record sound from wave or my stereo/mic & sometimes it records fine & other time it's broken up in precise moments like something is interrupting it.
I tried Cool Edit 2000 & Wavepad with the same results. Wavepad reports it doesn't hear sound & asks to configure it. I know my Patchmix DSP software is set right because it records with the 2GB DDR3. I even tried Cubase LE using the E-MU ASIO driver & all recording programs act like they don't hear sound with more then 2GB ram.
During my research last night I found others that have the same problem here:
http://www.productionforums.com/viewtop ... =4&t=12313
http://www.productionforums.com/viewtop ... =4&t=11653
http://productionforums.com/viewtopic.p ... 13&start=0
It seems to be that the E-MU sound card has a problem with anything over 3GB ram. I don't know if it's the drivers Patchmix the 4 cores in the CPU or what? But no matter what config I use I get the same results silence on recording with no peak meters bouncing in any recording software. I thought maybe if I bought PC3-10600 1333 memory it would work but I really doubt that will fix the problem after reading the above threads. Although they did say a lot of people are having success on a 64bit system using 8GBram recording with no problems. But no one is commenting. I guess the thread is too old.
I contacted E-MU & they pointed me to another old thread which was useless. Crucial ASUS & a few computer shops all said if the memory posts it should work & my problem is strange & they never heard of such a thing.
I paid $200 for the sound card it's the PCI version & really don't want to buy another one but I don't want to be stuck with only 2GB ram when running a 64 bit system.
I noticed others have tried disabling sound from their windows & graphics card & messed with turning on & off the on board sound to no avail. I have a GeForce 750ti & have done the same. I even watched E-MU Playback & Record in windows sound while trying to play music with 4GB, 8GB, & 16GB ram I can hear the music fine but windows sound set to Wave E-MU DSP in Recording acts like nothing playing.
Surely someone knows how to work around this problem. The E-MU cards are still selling on ebay for $150.
TheButcher69
Post by TheButcher69 » Fri Sep 04, 2015 7:57 am
Update:
No matter what I cannot get Audacity, Cool Edit 2000, or Wavepad to work. What I was told to try by jmail on another forum was to try Reaper & using the ASIO driver KNOCK WOOD I'm using 16GB of memory. Here's my setup in case anyone else runs into this. I REALLY wish Audacity could use the ASIO :( Damn copyrights!
Setup:
Click "Options" "Prefrences" "Device" change "Audio System" to "ASIO" change "ASIO Driver" to "E-MU ASIO"
Under "Enable Inputs" change "First" to (7: Aux 1 L) change "Last" (8: Aux 1 R")
Under "Output Range" change "3: ASIO 31/32" change "Last" "4: ASIO 31/32"
Click "Options" "Prefrences" "MIDI Devices" right click "KeyRig49" click "Enable Input" right click
"E-DSP MIDI Port [EC00]" click "Enable Output"
This will let you record from Computer/Stereo/Microphone & play "Keyrig49"
Post by Gale Andrews » Fri Sep 04, 2015 3:14 pm
TheButcher69 wrote:I'm not sure what the E-MU bit rate is but in Windows 8.1 sound it shows 48000 24 bit & I can not change it.
In that case, I recommend always using 48000 Hz project rate in Audacity.
TheButcher69 wrote:I even watched E-MU Playback & Record in windows sound while trying to play music with 4GB, 8GB, & 16GB ram I can hear the music fine but windows sound set to Wave E-MU DSP in Recording acts like nothing playing.
Are excessive effects being applied by EMU?
Post by Gale Andrews » Fri Sep 04, 2015 3:22 pm
TheButcher69 wrote:I REALLY wish Audacity could use the ASIO
It can. But you have to compile Audacity with ASIO support enabled.
TheButcher69 wrote:Reaper[...] Setup:
So is that working for you?
I think there might be other things you can do for Audacity and other apps to tweak resource management on the computer. Are the recordings bad, or only playback of them (that is, do the recordings play back OK to the built-in sound card)?
If the recordings are bad, why not post a sample here? See How to post an audio sample.
TheButcher69
Post by TheButcher69 » Fri Sep 04, 2015 5:39 pm
Thank for your reply Gale! I don't really know how to compile Audacity with ASIO.
The way I listed above is working.
The problem I was having before sounded exactly like this in the link here: https://www.youtube.com/watch?v=S6ZgmKRbTXM (Fast Forward to 1:30) All sounds were correctly heard while playing as Audacity was recording but upon playback of the recording that is what it sounded like. Although 99.9% of the time I couldn't even get Audacity, Cool Edit 2000 or Wavepad to record sound using MME, Direct Sound, WASAPI. Reaper recorded sound from all sources using WDM, Direct Sound, Waveout, & WASAPI but sounded the same as the link. ASIO was the only thing that fixed it with the above settings.
I will post a sound sample for you using Audacity.
TheButcher69
Post by TheButcher69 » Fri Sep 04, 2015 6:19 pm
Record Problem-old1.wav
(876.47 KiB) Downloaded 29 times
I'm using Crucial CT7348776 16GB of memory with an ASUS M4A77T/USB3, AMD Phenom II X4 955, E-MU1212m, Behringer 1622fx
To reproduce the sound problem I had to record from my stereo using WASAPI (loopback) with my E-MU1212m sound card. This is the only way I could get sound.
A .WAV file recorded fine using WASAPI (loopback)
MME & Direct Sound recorded silence.
Post by Gale Andrews » Sat Sep 05, 2015 7:57 pm
TheButcher69 wrote:The problem I was having before sounded exactly like this in the link here: https://www.youtube.com/watch?v=S6ZgmKRbTXM (Fast Forward to 1:30) All sounds were correctly heard while playing as Audacity was recording but upon playback of the recording that is what it sounded like. [...]
Thanks for the sample. So to be clear, does the waveform record as in your attached sample? If you zoom the recording to show about five seconds in the visible screen, do you see a series of spikes with "silence" (low level noise) either side? Or do the waves look correct when zoomed in, and you recorded that file with WASAPI loopback to demonstrate it's a playback problem?
Does the motherboard sound device have the same issues as the E-MU?
The resources issues that I had in mind you could tweak are listed in this article:
http://wiki.audacityteam.org/wiki/Manag ... nd_Drivers.
For example, you could look at whether you have reduced your paging file to allow for the larger memory, and likewise check if excessive swapping is actually occurring. At the bottom of that article there are a couple of Deferred Procedure Call testing tools you should try.
If a reduced latency API is going to help, then without compiling Audacity with ASIO support you could try Audacity 2.0.4 from http://www.oldfoss.com/Audacity.html. 2.0.4 has support for WDM-KS which can reduce latencies close to ASIO levels.
Be warned that that WDM-KS support could crash or blue screen your computer, hence we have not released WDM-KS-enabled Audacity except for version 2.0.4.
If there was a crash it would probably occur with your built-in sound card - it seems from forums that the EMU's WDM drivers do support WDM-KS, but that the WDM drivers are not as thoroughly implemented as the ASIO drivers. I'll leave researching that to you.
TheButcher69
Post by TheButcher69 » Sat Sep 05, 2015 11:37 pm
Your Welcome ;)
Yes waveform records as in sample.
I do see series of spikes with "silence".
Yes I recorded the sample with WASAPI loopback to demo the problem I'm having.
I never tested the Motherboard as I do not have the cable needed to connect to my mixer.
Thank you for the extra info!
