Suggestion
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
jack magee
- Operating System: Windows 7
Suggestion
I would like to suggest there should be a button on the GUI for the Shift+A Stop and set cursor function http://manual.audacityteam.org/o/man/tr ... u.html#set
Thanks Steve for pointing me to that option
- Quality Assurance
Re: Suggestion
Thanks I'll count your "vote" for that. But it probably won't happen in the default button set, as some are opposed to any extra buttons.
jack magee
Re: Suggestion
I think if an extra button cannot be added it is sad. Can the people opposed not ignore it.? Audacity has great potential but some things are too awkwardGale Andrews wrote:Thanks I'll count your "vote" for that. But it probably won't happen in the default button set, as some are opposed to any extra buttons.
Re: Suggestion
I think that other ways to tackle the "awkwardness" are being considered that do not require adding another button.jack magee wrote:I think if an extra button cannot be added it is sad. Can the people opposed not ignore it.? Audacity has great potential but some things are too awkward
There would be advantages for Audacity to run a sound stream continuously, rather than creating a new sound stream each time you play or record.
A consequence of Audacity doing this would be that "Pause" would be the same as "Stop and place cursor".
So effectively you have two "stop" states: one where playback/recording stops and the cursor "rewinds" back to where it started, and the other "stop" state would leave the cursor in its new position.
An additional benefit of this approach is that both types of "stop" allow editing (currently you can't edit while "Paused").
- Quality Assurance
Re: Suggestion
That would be much better, but we still have those who want an extra button for Loop Play, and the changes you describe may not happen soon.steve wrote:I think that other ways to tackle the "awkwardness" are being considered that do not require adding another button.jack magee wrote:I think if an extra button cannot be added it is sad. Can the people opposed not ignore it.? Audacity has great potential but some things are too awkward
So I still favour allowing customisation of Transport Toolbar for extra buttons and completely flexible button order.
waxcylinder
Re: Suggestion
Gale, do I assume that by "customization" you mean the ability to remove and add buttons in the toolbar?Gale Andrews wrote:So I still favour allowing customisation of Transport Toolbar for extra buttons and completely flexible button order.
If so, then I would support such a proposal - not least because one of the things I really dislike currently is the way some buttons change when the modifier keys Shift and Ctrl are held down (often not appropriate to the particular task in hand).
Peter.
jack magee
Re: Suggestion
Agree. Thanks for feedback guysGale Andrews wrote:That would be much better, but we still have those who want an extra button for Loop Play, and the changes you describe may not happen soon.steve wrote:I think that other ways to tackle the "awkwardness" are being considered that do not require adding another button.jack magee wrote:I think if an extra button cannot be added it is sad. Can the people opposed not ignore it.? Audacity has great potential but some things are too awkward
waxcylinder
Re: Suggestion
Jack,jack magee wrote:I would like to suggest there should be a button on the GUI for the Shift+A Stop and set cursor function http://manual.audacityteam.org/o/man/tr ... u.html#set
my interim workaround while this and other proposals for dealing with the same issue is to replace the existing shortcut Shift+A, which I always found awkward so seldom used, with a single keystroke shortcut.
The one I chose for myself is the NUMPAD_INSERT key (on my numpad it's a double-size key). All you have to ensure with that key is that the NUM_LOCK is not "on" (don't ask me how I know ...
For how to make alterations or additions to shortcut assignments see this page in the Manual: http://manual.audacityteam.org/o/man/ke ... ences.html
- Quality Assurance
Re: Suggestion
Yes. Ideally I would see it that you would open a customize dialogue that makes Transport Toolbar editable. You can then add buttons to the toolbar by dragging buttons from the customize dialogue to the toolbar, and remove buttons by dragging them to the customize dialogue. You could also drag any button on the toolbar into a different order.waxcylinder wrote:Gale, do I assume that by "customization" you mean the ability to remove and add buttons in the toolbar?Gale Andrews wrote:So I still favour allowing customisation of Transport Toolbar for extra buttons and completely flexible button order.
I don't know if Widgets can handle that on all three platforms.
If not then I support having more pre-ordained alternative transport toolbars to choose from in Interface Preferences.
I agree but at least one developer thinks that modifier keys changing buttons should be retained because it makes actions more discoverable. Few apps that I know do that. I would just rip it out as confusing and ugly if I had my way.waxcylinder wrote:One of the things I really dislike currently is the way some buttons change when the modifier keys Shift and Ctrl are held down (often not appropriate to the particular task in hand).
waxcylinder
Re: Suggestion
+1 to "rip it out as confusing and ugly"Gale Andrews wrote:I agree but at least one developer thinks that modifier keys changing buttons should be retained because it makes actions more discoverable. Few apps that I know do that. I would just rip it out as confusing and ugly if I had my way.waxcylinder wrote:One of the things I really dislike currently is the way some buttons change when the modifier keys Shift and Ctrl are held down (often not appropriate to the particular task in hand).![]()
It certainly is both of those
And re-purposing buttons like that is bad GUI design IMNSVHO
Peter.
