Win 7 64 bit - Audacity 2.1.1
I have problems when trying to copy or delete a secion of a clip. First I pause then select the piece which becomed hightlighted. But the copy/delete is greyed out until you stop. But when you stop the highlighted section disappears. If you stop first the cursor goes right back to the start?
Difficulty in editing sections of clips
jack magee
- Operating System: Windows 7
Re: Difficulty in editing sections of clips
Use "Stop and set cursor" (Shift + A) rather than "Stop".
http://manual.audacityteam.org/o/man/tr ... u.html#set
jack magee
Thanks. Very helpfulsteve wrote:Use "Stop and set cursor" (Shift + A) rather than "Stop".
