Change volume in one clip
jack magee
Operating System: Windows 7
Post by jack magee » Sun Aug 23, 2015 2:17 pm
Win 7 64 bit - Audacity 2.1.1
I made one mp3 from three mp3 by cutting out and pasting relevant sections. Clip one and two are OK. Clip three is a bit low. Can i increase volume slightly on clip three only. They are not music they are spoken narration
DVDdoug
Forum Crew
Re: Change volume in one clip
Post by DVDdoug » Sun Aug 23, 2015 3:52 pm
After the clips are combined, use the Envelope Tool to adjust one (or more) part of the recording.
jack magee
Post by jack magee » Mon Aug 24, 2015 9:01 am
DVDdoug wrote:After the clips are combined, use the Envelope Tool to adjust one (or more) part of the recording.
Thanks. I had to start again and it worked OK. I could not raise the volume with the envelope tool
Trebor
Post by Trebor » Mon Aug 24, 2015 4:31 pm
jack magee wrote:... I could not raise the volume with the envelope tool
You have to zoom-out on the vertical (amplitude/volume) scale to do that : place the cursor somewhere on the vertical scale, (it will become a magnifying-glass icon) , then click on the right-hand mouse-button.
The vertical scale now extends from +2 to -2 , ( rather than +1 to -1 ), allowing you to raise (amplify) using the envelope tool , rather than just make sections quieter.
Post by Gale Andrews » Tue Aug 25, 2015 2:54 pm
The other method is to raise the inner envelope points (second and third from the top).
