Compile error [SOLVED]
Please state:
kollins
Post by kollins » Sat Aug 22, 2015 12:53 pm
I'm trying to compile audacity on fedora 22 64-bits, but it fail on configure.
It gives me configure: error: ./configure failed for lib-src/libsoxr
Code: Select all
./configure: line 17: cmake: command not found
Re: Compile error
Post by steve » Sat Aug 22, 2015 12:55 pm
If libsoxr is not present on the system, it has to be built from the source code (included in the Audacity source code). Building libsoxr requires cmake.
kollins
Re: Compile error [SOLVED]
Post by kollins » Sat Aug 22, 2015 1:08 pm
Nice, I just installed cmake and it works.
Thanks.
