Plugin shutting down Audacity
themickster
XP Professional
LeCab worked for a time; it now shuts Audacity when I click Okay. I ran a system restore, defrag and reinstall but it still happens.
Re: Plugin shutting down Audacity
Which Audacity?
themickster
- Quality Assurance
That is a bogus version not made by us, so as you suggested in another post, please update to 2.1.1 from http://audacityteam.org/download/windows.themickster wrote:2.0.9.
If you have not yet done so, please see Important information for Windows XP users about the security risks of running XP now that Microsoft no longer support it.
If you still have the same problem in 2.1.1 supplied by us, please attach the Audacity Debug Report that will probably be produced after the crash.
themickster
2.0.9 installed from zip. LeCab now crashing Audacity when I click on it. Log attached.
There has never been a 2.0.9 version of Audacity.themickster wrote:2.0.9 installed from zip
- Quality Assurance
We cannot help you with bogus versions of Audacity made by others. I recommend uninstalling 2.0.9. scanning your computer for viruses and then installing Audacity 2.1.1 supplied by us. Download it here: http://audacityteam.org/download/windows.themickster wrote:2.0.9 installed from zip. LeCab now crashing Audacity when I click on it. Log attached.
themickster
My mistake. I sent the wrong one. The plugin shuts down with some impulses. Log attached.
- Attachments
- primary%3ADocs%2FAudacity_dbgrpt-3196-20020101T074432.zip
- (60.67 KiB) Downloaded 18 times
