noise reduction in 2.1.1 version
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
mickthefish
- Operating System: Windows XP
hi Gale.will there be any changes in the NOISE REDUCTION of the 2.1.1 version as apposed to the 2.1.0 version ?,as i am satisfied with the 2.1.0 version & dont fancy doing all my tapes & records again.im hoping the difference will be slight(if any).i use an xp home laptop & ion tape2/record2 pc units for importing.mickthefish.
Re: noise reduction in 2.1.1 version
The Noise Reduction effect in 2.1.1 is the same as in 2.1.0.
It is likely to also be the same in 2.1.2 though the default settings may be tweaked a little. The current defaults has "Frequency smoothing" at zero, but reports indicate that a higher value will often give slightly better results.
mickthefish
thanks steve,great to know NOISE REDUCTION will be the same in 2.1.1 version.i always use 4 in the FREQUENCY REDUCTION which works fine in all my imports---mick the fish.
