playback mode
BGPLAYER
playback mode
Post by BGPLAYER » Wed Feb 18, 2009 10:57 pm
Just wondering if there is a way to slow the playback way down to copy some words on a recording
stearman65
Re: playback mode
Post by stearman65 » Thu Feb 19, 2009 12:06 am
Not sure what you are asking here, my crystal ball is a little cloudy! However here goes, if you want to copy a single word and paste it into an existing recording? Open the recording, click view, zoom in to expand the screen view, you can do this any number of times until you are able to identify the particular word you want, drag the mouse across the words waveform, click copy, then click the waveform where you want to place the copied word and click paste, bingo. If that isn't what you are looking for, please explain further.
BGPLAYER
Re: playback mode
Post by BGPLAYER » Thu Feb 19, 2009 3:09 am
I think I did what you asked .I zoomed all the way until it would not go further and I never saw any words. Might be me !!!! What I'm trying to do is write all the words on paper from a song I recorded from a old cd I had. If it cant be done Ill just put headphones on and go little by little
Re: playback mode
Post by steve » Thu Feb 19, 2009 4:34 am
I think this may be what you are after: http://audacityteam.org/manual/index.ph ... on_Toolbar
BGPLAYER
Re: playback mode
Post by BGPLAYER » Fri Feb 20, 2009 5:11 am
I bet you just hate working with people like me. BUT I do appreciate every bit of effort you put towards your efforts.
I think I see the volume slider however there is no green arrow besides it so I am really confused now. This volume control is right above he tracks correct? That is what I want it to do is slow it down to decifer words http://audacityteam.org/forum/posting.p ... =12&t=8712#
stearman65
Re: playback mode
Post by stearman65 » Fri Feb 20, 2009 9:50 am
Hi BG
I'll try again. Assuming you have Audacity open and the song you want to read the words from imported and you have either stereo or mono blue waveforms on display???
Click the panel at the left hand end of the track that may have a title at the top and volume and balance slders below the title??? This will highlight the track (darken the waveform & blue out the L/H panel,) this means any actions will effect the whole track.
Now, on the top information bar click EFFECT, CHANGE SPEED, this brings up a box with a slider in, move the slider left until the indication reads -10%, click preview, this gives a 3 second burst of the effect you have actioned, if the track is now slow enough to pick out the words, click OK and the full track will be slowed, if it still isn't slow enough, take it down to -15% and try again. Once you have the correct speed, use the radio buttons to start stop & go back to select the section you want.
When you've done all you want, and need the track to go back to normal speed, either close the file without agreeing to the changes, or click EDIT, UNDO CHANGE SPEED until you have cleared all your changes.
You should now read the tutorials listed at the top of this page for further information.
Stearman65
BGPLAYER
Re: playback mode
Post by BGPLAYER » Mon Feb 23, 2009 7:28 pm
That is what I was talking about,thanks for the help .It took awhile to figure out what was meant by L/H but I stumbled across by mistake and the box turned blue,,HAHAHA :oops: :lol:
