Removing plugins
themickster
Removing plugins
Is there a way to remove effects that come with Audacity and are no longer needed after adding vst plugins?
Re: Removing plugins
If you are using the current Audacity 2.1.1, use "Manage" to disable the effects that you don't want.
http://manual.audacityteam.org/o/man/ef ... tml#manage
themickster
I'm still on 2.0.9 and will download 2.1.1.
