latest version of audacity
mickthefish
- Operating System: Windows XP
Will i be able to use the latest Version of audacity 2.1.1 in my Home Edition of Windows XP ?-mickthefish.
- Quality Assurance
Re: latest version of audacity
You will need to have Service Pack 3 installed (or Service Pack 2 if you are on 64-bit Windows XP). Also the CPU must support SSE2: http://en.wikipedia.org/wiki/SSE2. See http://audacityteam.org/download/windows#sysreq.
Also please see here about the security risks of running XP now that Microsoft no longer support it: Important information for Windows XP users.
mickthefish
thanks gale-should be no problems,i have al the requirements you stated-mickthefish
