connecting digital keyboard to Audacity
musicworx
Post by musicworx » Fri Aug 07, 2015 7:38 pm
...should I use the Audio Out 1/4 or the midi out...Audacity wont recognize the midi connection...windows 8.1 Casio 2400 B connector to usb dirct no mixer...thx
Re: connecting digital keyboard to Audacity
Post by Gale Andrews » Sat Aug 08, 2015 12:47 am
musicworx wrote:...should I use the Audio Out 1/4 or the midi out...Audacity wont recognize the midi connection...windows 8.1 Casio 2400 B connector to usb dirct no mixer...thx
Please see http://manual.audacityteam.org/man/FAQ: ... #keyboards.
Post by kozikowski » Mon Aug 10, 2015 6:58 pm
Possibly neither one. Audacity doesn't speak MIDI enough to make a recording and I'm betting your computer doesn't have a non-microphone audio connection.
I do it with my keyboard headphone connection into a Stereo USB adapter - Behringer UCA-202.
I used a 1/4" plug for the keyboard adapted to dual RCA connections for the UCA-202.
That's how I did all my sound effects.
http://www.kozco.com/tech/organfinale.mp3
