I'd love to cut and paste sync-locked tracks (one is mono, the other is stereo), but when I try to do that, one of the tracks ends up being silent.
This is explained here, Audacity silences one track when both are pasted: http://manual.audacityteam.org/manual/o ... html#paste
How do I cut and paste *both* sync-locked tracks, retaining the audio from both?
Thanks so much!
Cutting and pasting sync-locked tracks
billw58
Re: Cutting and pasting sync-locked tracks
First, make sure you have selected in both tracks. That is, the grey selection region extends through both tracks. Do Edit > Cut.
Next, select the spot you want to paste to in the top track. Now here's the trick: while holding down the shift key, press the down-arrow key - this will extend the selection into the lower track. Now do Edit > Paste.
-- Bill
-- Bill
Got it, thank you Bill!!!!!!!!!!!!
