How to disable "Exporting Data" popups?
Please state:
ribblle
Post by ribblle » Wed Aug 05, 2015 3:20 pm
I use audacity to break up my podcasts into 5 minute chunks with Regular Interval Labels and Export Multiple. Seeing as it takes 20 seconds for each chunk to export, I constantly get Exporting Data popups which i could accidentally stop by pressing enter. I've already disabled the edit metadata popups.
Re: How to disable "Exporting Data" popups?
Post by Gale Andrews » Wed Aug 05, 2015 6:54 pm
This is noted at http://bugzilla.audacityteam.org/show_bug.cgi?id=200#c2 - if you are a C++ programmer, please feel free to send us a patch or preferably a git pull request.
Gake
