is it not possible to insert spaces between tracks?
I am quite new to Audacity and cannot find an answer by using the search box.
Have loaded traacks from an old vinyl and wish to separate and numberthe individual tracks.
inserting spaces
Please state:
Please state:
Re: inserting spaces
What exactly are you wanting to do? Do you want to put the tracks onto a CD, or are they for an iPlayer or ....?
