High pitched,noise and helium like voice
WalkRacing
Post by WalkRacing » Sun Aug 02, 2015 9:29 am
Audacity 2.0.5
Windows 7 x64
File recorded via TeamSpeak v3
File recorded with SteelSeries Siberia V2 via USB
File full lenght 16min
Audio file linkhttps://www.dropbox.com/s/bkxpfs0yss1hxsp/TEST.wav?dl=0
First of all i am very very new/novice/newb to this to get this out of the way.Secondly i used TeamSpeak before as it's easier for me to record there interviews/friendly chat with other team members and so on,i hate skype.Thirdly it's first time i used the Siberia headseat in the past i had sennheiser (don't remember model,but it was the first with drop-down mic)and with the Sennheiser didn't had this problem.
What i want to know if it can be fixed or i have to record again?and if yes how?
As you can listen it's very very high pitched with a awfull background humming/noise and it sounds like i am on helium(maybe speed) and really don't know why, any help in this matter will be greattly apreciated
thank you
TEST.wav
(1.51 MiB) Downloaded 97 times
Trebor
Re: High pitched,noise and helium like voice
Post by Trebor » Sun Aug 02, 2015 12:23 pm
WalkRacing wrote:... What i want to know if it can be fixed or i have to record again?and if yes how? ...
The Helium effect can be reversed by dropping the pitch by about 50%, but in your case the result is not broadcast-quality because on your original audio every-other 1/10th of a second is missing :( ...
''Helium'' TEST, before-after , ( discard left track , then drop pitch by 50% ), last-take 2 copies interleaved.flac
the 1st "after" is very-gargley because every other 1/10th of a second has been chopped-out on the original audio. The missing bits can be patched(ish) by interleaving two copies of the gargley-version, 1/10th of a second out-of-sync.
(1.03 MiB) Downloaded 101 times
decrease pitch by 50 percent ( or thereabouts ).png (11.23 KiB) Viewed 1115 times
luke11685
Probationer
Post by luke11685 » Tue Mar 19, 2019 12:23 pm
Will this tool work with current Audacity version?Because I want to make voice of Porky the Pig and Tweety the Canary from Looney Tunes.
Trebor
Post by Trebor » Tue Mar 19, 2019 4:01 pm
... I want to make voice of Porky the Pig and Tweety the Canary from Looney Tunes.
You'll need to channel Mel Blanc or hire Bob Bergen ... https://www.youtube.com/watch?v=s3R0Riqm-H4
luke11685
Probationer
Post by luke11685 » Tue Mar 19, 2019 4:23 pm
Channel Mel Blanc kind of like spiritual connection in Phoenix Wright series?
