Numeric value in amplify effect
Please state:
yobeco
Post by yobeco » Fri Jul 31, 2015 3:50 pm
Hie
I'm using Audacity 2.1.1 with ubuntu 14.04 and I have a problem with the amplify effect.
When I want to assign a numeric valor, I can't write anything, with the numpad or the other keys of my keyboard (the are working very well). Curiously I can erase the numbers but I can't write...
I have to use the cursor...
I tried with Phather filter : the problem is here too... :shock:
Do you have the same problem ? :?:
Thank you
Re: Numeric valor in amplify effect
Post by steve » Fri Jul 31, 2015 4:09 pm
Is the problem only with the Amplify effect or other effects too?
What value are you trying to enter into which box?
Are you using the numbers on the numeric keypad, or the numbers above the letters on the keyboard?
Look in "Help > About Audacity > Build Information". Does it say that Audacity is using WxWisgets 2.8.x or WxWidgets 3.x.x?
yobeco
Post by yobeco » Fri Jul 31, 2015 4:30 pm
Thank you fer answer me :-)
> I just tried with echo filter, it's the same.
> Any one... It's how if I don't hit any key...
> I can't write anything, with the numpad or the other keys above the letters of my keyboard
> It's wxWidgets 2.8.12
Is any body have the same problem ?
Thank you :-)
Post by steve » Fri Jul 31, 2015 4:59 pm
I don't think this is a known problem. Audacity 2.1.1 works for me on Ubunty 14.04.
Where did you get Audacity 2.1.1 and how did you install it?
What language settings do you have, both for Ubuntu and for Audacity?
yobeco
Post by yobeco » Fri Jul 31, 2015 5:47 pm
I installed it from :
ppa:ubuntuhandbook1/audacity
And you ? How did you installed it ?
Is there any other way for 2.1.1 ?
I'm using french for Ubuntu and Audacity.
Post by steve » Fri Jul 31, 2015 8:12 pm
yobeco wrote:And you ? How did you installed it ?
I built it from the Audacity 2.1.1 release tarball: http://web.audacityteam.org/download/source
cyrano
Post by cyrano » Fri Jul 31, 2015 8:54 pm
This could be a very old and known hardware bug with some keyboards. Seems to happen to Adobe installers in the part where you type in the serial number. Problem happens only with numbers. Every other character works, but of course, the Audacity dialog only accepts numbers.
You could try to type a dot or comma, as these are allowed too. Just as a test.
On some keyboards, only the decimal part of the keyboard will allow you to type numbers. No good for laptops, as these usually don't have decimal keypads.
Have you tried another keyboard?
yobeco
Post by yobeco » Mon Aug 03, 2015 2:58 am
I made tests :
1- Only the 6 key can write in effects boxes (6 - and | incluided !!!). I did not noticed it before...
2- Back space is working too. (I can delete)
3- I tryed with an other keyboard, but it's the same.
4- I had a single additional small numeric keypad. I unpluged it and reboot : it's the same...
I don't understand. :|
cyrano
Post by cyrano » Mon Aug 03, 2015 8:19 am
yobeco wrote:I don't understand. :|
That makes two of us...
If the 6 works and other numbers don't, this should be another bug.
yobeco
Post by yobeco » Mon Aug 03, 2015 1:49 pm
And I can write the - and the | !!! (less and pipe)
Usualy, it's imposible ! Isn't it ?
But why with 2 keyboards ?
Who can inform the developers of this bug ? And How...
