Multiple export overwrite option
mickthefish
- Operating System: Windows XP
when using (export multiple) in audacity,is there any way to permenantly untick the (overwrite existing file) box as i keep forgetting to unclick it.it would also save time as i use quite a lot--mickthefish.
Reason: Given topic a more relevant title
Re: Multiple export overwrite option
No there isn't.
I'll move this to the "adding features" part of the forum.
I agree that it would be better if the user setting was retained, (and for safety, the default set to unchecked, don't overwrite).
waxcylinder
+1 from me to thatsteve wrote:I agree that it would be better if the user setting was retained, (and for safety, the default set to unchecked, don't overwrite).
@Steve: do you have the skills to "make it so"
Peter
- Quality Assurance
+1 but I don't want to default to off unless the user's setting is retained. I think most users want to overwrite.waxcylinder wrote:+1 from me to thatsteve wrote:I agree that it would be better if the user setting was retained, (and for safety, the default set to unchecked, don't overwrite).
@Steve: do you have the skills to "make it so"![]()
Peter
It's a very simple change; currently (before the change to wxWidgets 3) the code looks like (in \src\export\ExportMultiple.cpp at or near line number 352):waxcylinder wrote:@Steve: do you have the skills to "make it so"
Code: Select all
S.StartHorizontalLay(wxEXPAND, false);
mOverwrite = S.Id(OverwriteID).AddCheckBox(_("Overwrite existing files"), wxT("true"));
S.EndHorizontalLay();
Code: Select all
wxString overwriteExisting(wxT("true"));
gPrefs->Read(wxT("/Export/OverwriteExisting"), &overwriteExisting, wxT("true"));
mOverwrite = S.Id(OverwriteID).TieCheckBox(_("Overwrite existing files"), overwriteExisting, wxT("true"));
-Edgar
running Audacity personally customized 2.0.6 daily in a professional audio studio
occasionally using current Audacity alpha for testing and support situations
64-bit Windows Pro 10
mickthefish
Hi Gale-I suppose it depends on what project your working on wether you prefer the checkbox (ticked or un-ticked)if as you say most people prefer it set to overwrite.not an easy FIX for me though!-mickthefish.
How about just:Edgar wrote:It's a very simple change; currently (before the change to wxWidgets 3) the code looks like (in \src\export\ExportMultiple.cpp at or near line number 352):waxcylinder wrote:@Steve: do you have the skills to "make it so"needs two additional statements:Code: Select all
S.StartHorizontalLay(wxEXPAND, false); { mOverwrite = S.Id(OverwriteID).AddCheckBox(_("Overwrite existing files"), wxT("true")); } S.EndHorizontalLay();and the changeover from a generic wxWidgets checkbox to a Preferences-aware TieCheckBox.Code: Select all
S.StartHorizontalLay(wxEXPAND, false); { wxString overwriteExisting(wxT("true")); gPrefs->Read(wxT("/Export/OverwriteExisting"), &overwriteExisting, wxT("true")); mOverwrite = S.Id(OverwriteID).TieCheckBox(_("Overwrite existing files"), overwriteExisting, wxT("true")); } S.EndHorizontalLay();
Code: Select all
true);
Done in commit 246a8c
waxcylinder
Just saw that on the commit list
I tried that first and got a compiler warning (maybe because "true" can be defined as a BOOL or as an INT depending on the OS and/or compiler). If you search the code for other instances where we use a TieCheckBox you will see that, historically, it is done the way I did it. FYI your way does not work on my system (Windows 7, MSVS 2010 & 2013, WxWidgets 2.8 - next week I should be on Windows 10, MSVS 2015 & wxWidgets 3.0).steve wrote: How about just:Code: Select all
{ mOverwrite = S.Id(OverwriteID).TieCheckBox(_("Overwrite existing files"), wxT("/Export/OverwriteExisting"), true); }
-Edgar
