Export Multiple and FFmpeg
Help for Audacity on macOS.
waxcylinder
Re: Export Multiple and FFmpeg
Post by waxcylinder » Sun Jan 31, 2016 3:34 pm
Gale Andrews wrote:
chrzaszcz wrote:I'm reviving this thread because although the issue of labels, multiple tracks, and export multiple appears in the ‘Known Issues’ section of the 2.1.2 release notes, it appears to have been fixed
Thanks but it is not fixed: http://bugzilla.audacityteam.org/show_bug.cgi?id=1199. The steps to reproduce still reproduce - I have just done so. Not necessarily all labels will be affected.
Paul Licameli provided a patch fix for this: https://github.com/audacity/audacity/co ... 471bfbf129
It is in the latest nightly alpha 2.1.3 audacity-win-rd6b8080-2.1.3-alpha-30-jan-16
I just now tested it there and it looks to be fixed - so come the next release this should be ok
See: http://bugzilla.audacityteam.org/show_bug.cgi?id=1199
