audacity from command line...
Please state:
rcspam
Post by rcspam » Mon Jul 27, 2015 7:51 am
Hi,
If i launch audacity from Desktop (Unity, gnome shell, kde ...), no problems.
But when i launch it from command line. It search/analize 'wine pluging' before startup and it never start.
Then, I setup plugins from manage effect window to enable all, now a start from command line stop immediately without error but 'Glib warning'.
I don't understand why it start from desktop but not from terminal.
Is someone can light me?
Thank you
Re: audacity from command line...
Post by steve » Mon Jul 27, 2015 12:46 pm
rcspam wrote:But when i launch it from command line. It search/analize 'wine pluging' before startup and it never start.
Any different if you navigate to the directory where the Audacity executable is located before launching it?
rcspam wrote:It search/analize 'wine pluging' before startup and it never start.
If / when you use Audacity 2.1.1 you can enable/disable individual plug-ins via the plug-in manager (at the top of the Effect, Generate and Analyze menus).
