electric classical sound
suttlemyre
Post by suttlemyre » Sat Jul 25, 2015 9:18 pm
has any one asked for this effect, (i run a strat thru a tube amp, it sounds dirty an mean), if so where should i start.All so have A/E acoustics.I am looking for a sharp smooth milk sound.
Trebor
Re: electric classical sound
Post by Trebor » Sun Jul 26, 2015 5:01 pm
There are amp and pre-amp simulator VST plugins, some will work in Audacity on Windows ...
http://bedroomproducersblog.com/2012/02 ... u-plugins/
suttlemyre wrote:... i run a strat thru a tube amp, it sounds dirty an mean ...
If it's already tubey & dirty enough , you may just need dynamic-range-compression to reduce the variation in volume.
Audacity has a built-in compressor ... http://manual.audacityteam.org/o/man/compressor.html
Other free compressor plug-ins are available, e.g.Chris's Compressor.
Paul-L's de-clicker plugin can be used to remove any conspicuous plectrum noises from a guitar track , for a smoother sound.
