I merged your posts because they seem to be about the same issue.
You probably cannot rescue it to any great degree. Have you tried Noise Reduction?
You did not attach any audio. Please see How to post an audio sample.
Information about using Audacity To Enhance quality audio
- Quality Assurance
Re: Information idea fix the quality using audacity
