no vst scanning for plugins for new ones :-(
yugioh47
Post by yugioh47 » Fri Jul 24, 2015 9:01 pm
hi there here is a bug report for my feed back. here's a screenshot:
https://www.dropbox.com/s/igxozkew38z8m ... 7.png?dl=0
Re: no vst scanning for plugins for new ones :-(
Post by Gale Andrews » Fri Jul 24, 2015 10:13 pm
yugioh47 wrote:hi there here is a bug report for my feed back. here's a screenshot:
Please, as you are on Windows, post details of anything you think could be an Audacity bug in the Windows board http://forum.audacityteam.org/viewforum.php?f=46. I have moved your post here.
Please tell us exactly what version of Audacity it says at Help > About Audacity... . Give us all three numbers.
In Audacity 2.1.1, the system for registering plug-ins has changed.
After adding plugins to the Audacity Plug-Ins folder (or to the appropriate system location), you don't restart Audacity. Instead you use Effect > Manage... (at the top of that menu), then look in the list of "All" plugins and click to select the effect(s) you added. With the effect(s) you want to register selected, click the "Enable" button then click OK.
It may be quicker to click the "New" radio button then you will only see effects that have not yet been registered.
The same system is also used for Audacity's built-in effects and shipped plugins (like Adjustable Fade or High Pass) - most of those effects are enabled by default, but you can disable them at Effect > Manage... if you want to shorten the Effect Menu.
Please read here about the Plug-in Manager dialogue: http://manual.audacityteam.org/o/man/ma ... yzers.html.
yugioh47
audacity 2.1.1 isn't scanning for new plugins :-(
Post by yugioh47 » Sat Jul 25, 2015 2:23 pm
hi there, i've posted this yesterday. audacity 2.1.1 doesn't have that option to scan for new plugins and install them.
hereis a screenshot of audacity 2.1.1:
Reason: :Post moved to correct forum and merged with existing topic
Post by Gale Andrews » Sat Jul 25, 2015 2:59 pm
Please do not double post. Do not post bug reports in Feedback and Reviews. You are on Windows, so please post in the Windows board (here).
Please read the reply you have already received http://forum.audacityteam.org/viewtopic ... 08#p281508.
Trebor
Post by Trebor » Thu Mar 01, 2018 4:04 am
shawn20 wrote:I have windoes 8 can any one tell me about,how to scan for tracktion plugins?
In Audacity 2.2.X you have to enable new plugins before they appear on the plugins menu.
The Tracktion plugins do work in Audacity on Windows,
but the free-trial ones I tried seemed to be adding noise intermittently, (spoilers ?)
Traction compressor.gif (175.86 KiB) Viewed 465 times
https://www.tracktion.com/products/daw- ... collection
