Hi Gale. I can record with MME support in 32bit with no problem. My posting above (with the screenshot) shows that my right channel has samples in the -115dB range. This file was created with MME support, not DirectSound. Thus, it proves the file is not 16bit. As well, eharmonica (the op) tested both MME & DirectSound files I created and both were 24bit. Just fyi.Gale Andrews wrote:The "DirectSound" choice for SoundBlaster that Thunderstick is using in the Audacity Audio I/O Preferences might be the key here, as the other choice (MME) only supports 16-bit recording (even with 24-bit hardware).
thunderstick.
