Fix for Audacity 2.1.1 not launching
Help for Audacity on macOS.
Post by Gale Andrews » Tue Jul 21, 2015 3:10 am
On a few machines, Audacity 2.1.1 may fail to launch without any warning message or crash report appearing. Audacity will not be running in Activity Monitor.
If this problem occurs:
  1. Open Finder, use Go > Go to Folder and type:
    Code: Select all
    ~/Library/Application Support/audacity/
  2. In that "audacity" folder, open the "audacity.cfg" file in TextEdit.
  3. If you see a line under "Directories" that looks like
    Code: Select all
    TempDir=/tmp/audacity1.2-<your user name>
    delete that line and try launching Audacity again.
  4. Or you may try deleting audacity.cfg (note that this resets all your preferences).
