Help for Audacity on macOS.
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
fprasuhn
Post
by fprasuhn » Mon Jul 20, 2015 6:01 pm
I just attempted an updated fir my copy of Audacity to 2.1.1 on my Mac OS 10.10.4.
Download completed well.
Install occurred with no problems.
I used CTRL + click to open.
I told OS to open application.
Icon bounced once.
No Audacity.
I re-downloaded the DMG file and repeated process. Still no Audadicty.
Help, please.
MSewall
Post
by MSewall » Tue Jul 21, 2015 12:57 am
My experience also. OS 10.10.4, audacity-macosx-ub-2.1.1.dmg I cleared the query about "not an App Store or identified developer." Once bounce and no sign of the app. I reverted to 2.1.0 .0. It works fine.
fprasuhn
Post
by fprasuhn » Tue Jul 21, 2015 12:45 pm
Gale:
Dealing with the cfg file worked perfectly. Thank you for your assistance.
As requested, I attached the original audacity.cfg as a text file. I also attached the new cfg file (audacity cfg new.txt) in case the comparison would be useful.
Thank you, again, for the help...fred
- audacity.txt
- (2.47 KiB) Downloaded 21 times
- audacity cfg new.txt
- (1.25 KiB) Downloaded 16 times
