hiss noise
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
vikitren
hiss noise
Post by vikitren » Mon Jul 20, 2015 4:45 am
u-phoria umc22 , when start record with audacity , i got hiss noise from this .......i just test level without put any mic from device got hiss noise when start record,,,,,,,if put mic got more ,,,,,,what is the problem,,,,, HOW TO SOLVE IT
Re: hiss noise
Post by steve » Mon Jul 20, 2015 8:15 am
Some amount of hiss is inevitable (even with the very best equipment set up to perfection).
The amount of hiss should be very small compared to the signal level. (this is called the "signal to noise ratio" or "SNR").
If the hiss seems to be excessive, check the levels. The "gain" on the umc22 needs to be high enough to give a good strong signal, and then the recording level in the Windows Sound Control Panel should be low enough to avoid distortion - you are aiming for a maximum peak level in the recording of about half the track height.
For a microphone, ensure that you use the 3 pin "XLR" connection (not a jack plug).
mickthefish
Operating System: Windows XP
Re: hiss noise
Post by mickthefish » Tue Jul 21, 2015 10:08 am
hi Steve-yes i agree with you some ammount of Hiss IS UNAVOIDABLE.however if you compare a tape with no noise reduction to one with noise reduction,the results are unmistakable.noise reduction has made all my tapes a treat to listen to.nothing is perfect----mickthefish.
Re: hiss noise
Post by Gale Andrews » Tue Jul 21, 2015 4:52 pm
vikitren wrote:u-phoria umc22 , when start record with audacity , i got hiss noise from this .......i just test level without put any mic from device got hiss noise when start record,,,,,,,if put mic got more ,,,,,,what is the problem,,,,, HOW TO SOLVE IT
If you have more questions, please post in the Help Forum http://forum.audacityteam.org/viewforum.php?f=45, in the board for whatever operating system you are using.
This makes it easier to give you a relevant answer.
