Opening AAC stream ripped from DAB+ radio
Kamil1000
Post by Kamil1000 » Sun Jul 19, 2015 12:47 pm
Hi!
I have problem with opening AAC audio stream in Audacity, that is ripped from DAB+ terrestrial digital radio. Audacity says, that the selected file is Advanced Audio Coding file and Audacity don't open these files. This error is very strange, because I can open other AAC streams normally in Audacity. I have Windows 8.1 and I updated Audacity to 2.1.1 version. In Audacity I have selected current FFmpeg libraries (2.2.2). I rip AAC stream from digital radio using [url=http://www.ukwtv.de/cms/downloads-aside ... gsinn.html]DAB Player software[/url] and this is 1:1 copy of broadcast stream. I tried change stream container to Matroska, but no effect. I checked also rips with different AAC stream version (AAC-LC and HE-AAC). Digital radio streams aren't DRM-protected, because Windows Media Player (using LAV Splitter and ffdshow audio decoder) and VLC normally plays these rips.
Re: Opening AAC stream ripped from DAB+ radio
Post by steve » Sun Jul 19, 2015 12:58 pm
Do you have Ffmpeg installed? (see http://manual.audacityteam.org/o/man/fa ... html#winff)
Does this file play in VLC?
Kamil1000
Post by Kamil1000 » Sun Jul 19, 2015 1:11 pm
Yes, yes, I wrote earlier:
Kamil1000 wrote:In Audacity I have selected current FFmpeg libraries (2.2.2).
Kamil1000 wrote:VLC normally plays these rips.
VLC decodes these files internally.
Post by steve » Sun Jul 19, 2015 1:16 pm
Is the problem with "one" file that was recorded with your DAB Player software, or is it a problem with "all" files that you record with that software?
Kamil1000
Post by Kamil1000 » Sun Jul 19, 2015 1:26 pm
All rips created by this software don't open in Audacity. In our national multiplex some radios using AAC-LC codec and some using HE-AAC codec, however both don't open in Audacity.
Post by steve » Sun Jul 19, 2015 1:38 pm
I guess there must be something a bit different between those AAC files and "normal" AAC files that open in Audacity. :?
If you can open those files in VLC, then you could use VLC to decode them into standard WAV files, and then open the WAV files in Audacity.
Also, "Foobar 2000" is good for converting audio file types.
Post by Gale Andrews » Sun Jul 19, 2015 2:27 pm
Can you provide a short example of one of these files that won't import into Audacity?
See How to post an audio sample.
Kamil1000
Post by Kamil1000 » Sun Jul 19, 2015 2:57 pm
Here is a sample file.
Radio Rytm_2015-07-18_222343.mp4
(1.08 MiB) Downloaded 569 times
cyrano
Post by cyrano » Sun Jul 19, 2015 5:02 pm
Browsers on Mavericks:
FF shows the player, plays but no sound.
Safari shows the player, plays, but only regular 1 KHz beeps.
Chrome shows the warning that the Quicktime internet plugin isn't supported and a broken plugin window.
Audio apps:
Audacity can't import it. The result is silence.
iTunes doesn't play.
Only VLC player sees this as a normal audio file and plays the music.
Baudline reports a bad header and stops.
Xact (Sox) doesn't know what file this is...
Post by kozikowski » Sun Jul 19, 2015 7:46 pm
So that's either very custom media or it got damaged before you got it.
