No sound win 7 64bit [SOLVED]
jack magee
Operating System: Windows 7
Post by jack magee » Sat Jul 18, 2015 1:14 pm
Apologies i exceeded logins as i was on other pc and could not recall password.
I am on win 7 64 bit and Audacity 2.1.0 will not record from my computer any sound playing or any website sound. Here is a screenshot of my settings. There is no stereo mix on this pc. Not disabled or not shown it is just not on it
Re: No sound win 7 64bit
Post by Gale Andrews » Sat Jul 18, 2015 2:13 pm
If you still have Audacity Portable 2.1.0, sorry but as previously explained, we do not make that and so cannot provide support for it.
I recommend updating to the new Audacity 2.1.1 supplied by us: http://audacityteam.org/download/windows.
Using 2.1.1, you will have to use the Windows WASAPI (loopback) choice in Device Toolbar to record computer playback. For details, have a look at Tutorial - Recording Computer Playback on Windows - Audacity Manual.
Obviously we assume you have the copyright holders' permission to record from the internet.
jack magee
Post by jack magee » Sat Jul 18, 2015 2:29 pm
Gale Andrews wrote:If you still have Audacity Portable 2.1.0, sorry but as previously explained, we do not make that and so cannot provide support for it.
I got version 2.10 which is installed in C:\Program Files (x86)\Audacity
That is yours and not the portable one? Can i install v 2.1.1 over that? Thanks
it is uploaded by people i work for
Post by Gale Andrews » Sat Jul 18, 2015 4:38 pm
If Help > About Audacity... says "2.10" that is definitely not made by us. Whatever it says, I would uninstall that version.
Install 2.1.1 from http://audacityteam.org/download/windows. Half way through the installation, check (tick) the "Reset Preferences" box and say yes to reset preferences when you launch 2.1.1. Then you will start with clean Audacity settings.
To run our Audacity portably, please see http://manual.audacityteam.org/o/man/pr ... l#portable.
jack magee
Post by jack magee » Sat Jul 18, 2015 4:59 pm
This is what it says
Post by Gale Andrews » Sat Jul 18, 2015 5:10 pm
If you got that 2.1.0 in your picture from http://portableapps.com/apps/music_vide ... y_portable it's a modified version of Audacity. Audacity Portable is not our project so we do not know the full extent of their modifications.
If you download 2.1.1 as suggested from http://audacityteam.org/download/windows then we will be able to offer you support with that version.
jack magee
Post by jack magee » Sat Jul 18, 2015 5:20 pm
I am not sure where i got it. I was not aware it was OK for them to modify it.Whereever i got it I assumed it was yours.
I have 2.1.1 now and am installing it. Thanks
Edit. Now have version 2.1.1 and it records. Thanks for your help
Post by Gale Andrews » Sat Jul 18, 2015 5:53 pm
jack magee wrote:I was not aware it was OK for them to modify it
Anyone can modify Audacity if they make the modified source code available under the same General Public License as ourselves.
Audacity Portable have (at least) modified Audacity to get the extra "portable" features that they offer.
jack magee wrote: Now have version 2.1.1 and it records.
Excellent :)
jack magee
Re: No sound win 7 64bit [SOLVED]
Post by jack magee » Sat Jul 18, 2015 6:02 pm
Excellent :)
Oh I see thank you for your help
