The move was only so that we could request the problematic audacity.cfg file.brianj wrote:Renaming the .cfg file and keeping it in the same folder seems not to work but moving it to another folder as suggested seems to do the trick.
There is no need to move the file, just delete audacity.cfg if you don't mind losing your custom settings.brianj wrote: As this seems to be a general problem with the current OS, it looks like the instruction to move the file should be included in the installation instuctions (alternatively an installer script should do the job but obviously that makes everything more complicated. Or of course an update can be produced that will fix the problem.
I don't think everyone has this problem. Did your previous audacity.cfg have lines like:
Code: Select all
[Directories]
TempDir=/tmp/audacity1.2-<your user name>
If so, the TempDir=/tmp/audacity1.2-<your user name> line is the issue. You can just delete that line in the .cfg file and retain your other settings.
I added a mention of this to the "Mac OS X" yellow box at the top of http://wiki.audacityteam.org/wiki/Release_Notes_2.1.1. We will look into it of course.
