Hi,
I recently updated to Yosetime and now I can't instal Audacity. I have followed the instructions in the sticky thread but no luck. There does not seem to be a dmg file in my download?
Please help!
Updated to Yosetime - can't get Audacity
Re: Updated to Yosetime - can't get Audacity
Perhaps you have the wrong download.jahbuzzz wrote:There does not seem to be a dmg file in my download?
Try re-downloading the "Audacity 2.1.1 .dmg file" from here: http://web.audacityteam.org/download/mac
Instructions for installing are on that page. Note also the "Known Issue:" about security settings.
