No line input on vista home
MisterC
Post by MisterC » Sun Feb 08, 2009 12:05 pm
Downloaded the latest version of audacity from the web site. Installation was successful except for one thing. I cannot select the line imput. It is a solid grey with no drop down box. I am using the beta version on my XP and it works fine,. Pls help.
MisterC
roy windmill
Re: No line input on vista home
Post by roy windmill » Wed Feb 11, 2009 11:40 am
HI, Did you get an answer to your problem? I am having the same difficulty although I have Windows xp. I would like to know how you solved it. Thanks, Roy
Post by steve » Fri Feb 13, 2009 11:50 am
On your desktop (for Windows in the bottom right corner near the clock) you should find a loudspeaker icon from which you can open up either the Windows Mixer, or a custom Sound Card Control Panel. Use that to select and enable your recording source. Note that on some modern machines there is a second icon that holds additional settings for automatic gain control or other recording effects - all effects should be turned off or you will get weird things happen with your recording.
