Audacity not recording in Ubuntu Studio
Please state:
Please state:
seanhussey9
Is there anything I can do to get Audacity to record again in Ubuntu Studio?
I have been using an M-audio 1010LT soundcard with Audacity since Ubuntu Studio 12.04. Recently on Ubuntu Studio 15.04 / Audacity 2.0.6, the cursor got stuck on 0 seconds, was blinking, and not recording. First I tried increasing the latency, (didn't help) then I unchecked overdub (didn't work). Software playthrough was already unchecked, so I tried it checked and then put it back since it didn't make a difference. As a last resort, I removed Audacity and reinstalled it, but to no avail. Finally, I bit the bullet and reinstalled the OS, but no dice.
Overview:
1. Increased latency
2. Unchecked overdub
3. Checked then unchecked software playthrough
4. Reinstalled Audacity
5. Reinstalled Ubuntu Studio 15.04
I then played with the latency settings some more just for kicks, but nothing. Thanks for any suggestions for step #6.
Overview:
Re: Audacity not recording in Ubuntu Studio
First, reset the Audacity Preferences back to defaults by deleting "audacity.cfg" ( ~/.audacity-data/audacity.cfg)
Then ensure that your M-audio 1010LT is operating correctly.
Then reboot.
Then launch Audacity and click on "Help > Audio Device Info".
Copy and paste the output into your reply.
Then reboot.
seanhussey9
Thanks for the help. Audacity version is 2.0.6. Audio Device Info is pasted below.
Code: Select all
Default recording device number: 12
Default playback device number: 12
Device ID: 0
Device name: Intel ICH5: - (hw:0,0)
Host name: ALSA
Recording channels: 2
Playback channels: 2
Low Recording Latency: 0.008707
Low Playback Latency: 0.008707
High Recording Latency: 0.034830
High Playback Latency: 0.034830
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
Device ID: 1
Device name: Intel ICH5: MIC ADC (hw:0,1)
Host name: ALSA
Playback channels: 0
Low Recording Latency: 0.008000
Low Playback Latency: -1.000000
High Recording Latency: 0.032000
High Playback Latency: -1.000000
Supported Rates:
Device ID: 2
Device name: Intel ICH5: MIC2 ADC (hw:0,2)
Host name: ALSA
Supported Rates:
Device ID: 3
Device name: Intel ICH5: ADC2 (hw:0,3)
Host name: ALSA
Supported Rates:
Device ID: 4
Device name: Intel ICH5: IEC958 (hw:0,4)
Host name: ALSA
Recording channels: 0
Low Recording Latency: -1.000000
Low Playback Latency: 0.008000
High Recording Latency: -1.000000
High Playback Latency: 0.032000
Supported Rates:
48000
Device ID: 5
Device name: M Audio Delta 1010LT: ICE1712 multi (hw:1,0)
Host name: ALSA
Recording channels: 12
Playback channels: 10
Low Recording Latency: 0.008685
Supported Rates:
8000
9600
11025
12000
16000
22050
24000
32000
44100
48000
88200
96000
Device ID: 6
Device name: sysdefault
Host name: ALSA
Recording channels: 128
Playback channels: 128
Low Recording Latency: 0.021333
Low Playback Latency: 0.021333
High Recording Latency: 0.021333
High Playback Latency: 0.021333
Supported Rates:
8000
9600
11025
16000
22050
32000
44100
48000
88200
176400
352800
Device ID: 7
Device name: front
Host name: ALSA
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
Device ID: 8
Device name: iec958
Host name: ALSA
Supported Rates:
48000
Device ID: 9
Device name: spdif
Host name: ALSA
Supported Rates:
48000
Device ID: 10
Device name: pulse
Host name: ALSA
Recording channels: 32
Playback channels: 32
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 11
Device name: dmix
Host name: ALSA
Supported Rates:
48000
Device ID: 12
Device name: default
Host name: ALSA
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 13
Device name: /dev/dsp
Host name: OSS
Recording channels: 16
Playback channels: 16
Supported Rates:
Selected recording device: 12 - default
Selected playback device: 12 - default
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Available mixers:
Available recording sources:
0 - Line:0
1 - CD:0
2 - Mic:0
3 - Video:0
4 - Phone:0
5 - Aux:0
6 - Mix:0
7 - Mix Mono:0
Available playback volumes:
0 - Master:0
1 - Master Mono:0
2 - Headphone:0
3 - PCM:0
4 - Line:0
5 - CD:0
6 - Mic:0
7 - Phone:0
8 - IEC958 Playback AC97-SPSA:0
9 - Aux:0
Recording volume is native
Playback volume is native
Reason: wrapped audio device info in code tags for readability
That all looks OK.
Set Audacity to record, then open "PulseAudio Volume Control" (if it's not installed, install "pavucontrol") and in the Recording tab, select the input that you want to record from.
seanhussey9
Do I need to change the latency correction settings? I tried recording and got this error message:
Latency Correction setting has caused the recorded audio to be hidden before zero.
Audacity has brought it back to start at zero.
You may have to use the Time Shift Tool (<---> or F5) to drag the track to the right place.
Thank for all the help.
- Quality Assurance
The recording is stalling. What input are you trying to record from in pavucontrol?seanhussey9 wrote:Do I need to change the latency correction settings? I tried recording and got this error message:
Are you choosing the "pulse" input in Device Toolbar?
seanhussey9
Interface host has a choice of ALSA and OSS, and is set to ALSA
When playback and recording device are set to default, sysdefault, M-Audio 1010LT ICE 1712, spdif, or pulse the recording bar sits at zero and doesn't move.
I also went into my bios and turned off my internal audio card just in case it was interfering with the M-Audio 1010lt PCI card.
Thanks for all the help.
- Quality Assurance
At Edit > Preferences... then "Recording", did you try increasing "Audio to buffer"? You said you changed "latency" but "Latency Correction" does not help you start recording, it just time shifts overdub recordings once completed.seanhussey9 wrote:Interface host has a choice of ALSA and OSS, and is set to ALSA
How many tracks are you trying to record? Does one track record with Audacity set to one recording channel?
seanhussey9
I looked through all the suggestions and someone mentioned making sure the M audio 1010lt sound card was working.
The computer was detecting the PCI sound card, but I opened up the box anyway to see if it was loose. Turns out it was covered with dust from the fan of my new AGP video card. I moved the sound card over one slot and cleaned out all the dust from the box.
After reinstalling everything, the card works fine. I'm guessing the dust was causing some sort of short circuit. Thanks for all the help.
