One track to one instrument or voice
Please state:
otar
Post by otar » Thu Jul 16, 2015 10:09 am
Hi everyone,
I wonder, if it's possible to assign each track to each voice.
In my case, there are polyphonic recordings and I would like to have each voice in the separated tracks.
Is this possible in Audacity? If not, could you indicate me the program that could do this task?
My OS is LXLE.
Thank you
Re: One track to one instrument or voice
Post by steve » Thu Jul 16, 2015 10:20 am
otar wrote:If not, could you indicate me the program that could do this task?
Not with Audacity.
Possibly with Melodyne by Celemony, however, the software is rather expensive, and it will be very labour intensive (will probably take several weeks of continuous work to separate the instruments of one song).
otar
Post by otar » Thu Jul 16, 2015 1:47 pm
So free versions aren't available?
Post by steve » Thu Jul 16, 2015 2:21 pm
I think they do a 30 day trial, but it's Windows or Mac OS X.
The full version is about $350 US.
Check their website.
otar
Post by otar » Fri Jul 17, 2015 9:48 am
So there is only this program(Melodyne by Celemony) that would allow do this? No other programs that would be free?
Post by steve » Fri Jul 17, 2015 10:40 am
There is also the much less sophisticated "Elevayta - Extra Boy Pro", which is much less expensive and the cut down version "Extra Boy", but I wouldn't expect either of these to work very well in most cases.
The "almost free" cut-down version is hidden near the end of the downloads page. http://www.elevayta.com/
These are also Windows only (VST) and I don't know if they work with Audacity (I'm on Linux, so I've not tested).
Post by Gale Andrews » Fri Jul 17, 2015 3:39 pm
otar wrote:So there is only this program(Melodyne by Celemony) that would allow do this? No other programs that would be free?
You could try ISSE : An Interactive Source Separation Editor - I gave you a cached URL because SourceForge is offline at present.
You can always use your favourite search engine yourself to look for alternatives.
otar
Post by otar » Sat Jul 18, 2015 4:05 pm
thank you
