Merci de noter que la plupart des membres de l'assistance d'Audacity ne parlent qu'anglais. Par conséquent, nous ne pouvons garantir une réponse aux questions en français.
RobinDherde
Post
by RobinDherde » Wed Jul 15, 2015 9:54 am
When I try to record with my behringer U-PHORIA UMC202 I have a problem...
It's written : "'Le réglage de correction de latence a caché l'audio enregistré, avant le zéro.
Audacity l'a ramené au zéro.
Vous pourrez utiliser l'outil de glissement temporel ( ou F5) pour glisser la piste à sa place"
Sorry it's french, I searched for days and I can't find an issue... please help me!
- Site Admin
Post
by steve » Wed Jul 15, 2015 12:30 pm
Sorry, I don't speak French.
That message will occur if the recording stalls (stops prematurely) when recording a new track.
Check your settings in the
device toolbar (you should probably have "host" set to MME if you are on Windows, and the recording and playback devices set to your USB UMC202 device.)
In the "Transport" menu, "Software Playthrough" should be off (not selected).
