Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
stearman65
Post
by stearman65 » Mon Jul 06, 2015 10:44 am
Trebor wrote:stearman65 wrote:I've attached a screen shot of the Audacity make up.
The voice-over level-slider is too high: the value looks around +9dB, [ "+" means boost, i.e. louder ] ....
Given the amplitude of your voice-recording, that level-slider should be about zero.
Anything above about +6 will produce the flattened envelope ...
After turning down that [red] slider , it may be too quiet for you , then turn up the "output level" slider ...
Thanks Trebor
Tried that & it appears the problem is solved.
Regards Stearman65.
