common background separation
atenzor
Post by atenzor » Sun Jul 05, 2015 2:36 am
Assuming the following situation:
-2 stereo tracks
-each has the same background music/sounds
-one has English spoken words mixed in, other has another language mixed in
is there a way to analyze/process/separate the common background music/sounds based on
those two stereo inputs?
thanks!
Trebor
Re: common background separation
Post by Trebor » Sun Jul 05, 2015 3:35 am
Kn0cK0ut plugin may be worth a try , but don't get your hopes up.
[ If the voices are simultaneous there will be occasionally be common frequencies within the speech, even though they are in different languages, those sounds will also end up in the "common" result ].
atenzor
Post by atenzor » Tue Jul 07, 2015 2:39 am
Trebor wrote:Kn0cK0ut plugin may be worth a try , but don't get your hopes up.
I don't see how a center-channel remover/isolator is going to help me here. Are you sure you understood my initial question? or maybe I didn't understand what you meant when you suggested knockout plugin, but last time I checked, I don't think it can do what I am looking for.
Trebor
Post by Trebor » Tue Jul 07, 2015 5:16 am
atenzor wrote:I don't see how a center-channel remover/isolator is going to help me here.
Combine the two left channels as a stereo-pair, then and apply a centre-isolator to that pair, the result will be a mono track, consisting of what is common to the two left channels. Repeat with the two right channels.
atenzor wrote: I don't think it can do what I am looking for.
You may very well be right : where the two different voices coincide their common-frequency-content will be isolated too.
atenzor
Post by atenzor » Wed Jul 08, 2015 3:02 am
but the problem is they only share the same background music, HOWEVER, not at the same amplitude... so this trick might not work if it assumes both background music levels will be the same amplitude? if not, i could try it and see what happens...
Trebor
Post by Trebor » Wed Jul 08, 2015 4:13 am
atenzor wrote: ... but the problem is they only share the same background music, HOWEVER, not at the same amplitude... so this trick might not work if it assumes both background music levels will be the same amplitude? ...
The discriminating-factor the kn0ck0ut plugin uses is frequency [spectral] , not amplitude.
[ Nor does the phase have to exactly match, as is the case with other isolation methods ].
Kn0ck0ut does include bubbly digital processing artifacts : so the result is not studio-quality.
atenzor
Post by atenzor » Sun Jul 12, 2015 10:06 pm
@Trebor
can I use 0.8 version?
I don't have Linux for LV2 and not good with compiling code from source. Is there a way to use that newer version under Windows? would be awesome!
Trebor
Post by Trebor » Mon Jul 13, 2015 1:10 am
atenzor wrote:@Trebor
I've only ever used kn0ck0ut on Windows, just a VST plugin. I've never attempted to use kn0ck0ut on Linux.
My copy of kn0ck0ut probably isn't the latest ...
This is the copy of Kn0ck0ut I have (on Windows).png (9.79 KiB) Viewed 1001 times
Again don't get your hopes up, here is a typical result of Kn0ck0ut : it sounds computery ... https://youtu.be/KDV0WQRO0tE?t=25s
Robert J. H.
Post by Robert J. H. » Mon Jul 13, 2015 5:30 am
The attachment This is the copy of Kn0ck0ut I have (on Windows).png is no longer available
Trebor, are you aware that the next version includes the new "Vocal Reduction and Isolation" plug-in?
It is e.g. available in the current RC-3 download of Audacity 2.1.1.
I've recorded the beginning of the tutorial you've linked to.
The original audio track is only played for a little while and the guy keeps talking over it.
Anyways, the second half is the isolated version (strength 50, normalized).
The results are comparable to knockout, I should think, the more as the source is far from being ideal.
B-A isolation.mp3
(519.18 KiB) Downloaded 45 times
Cheers
Robert
atenzor
Post by atenzor » Mon Jul 13, 2015 5:49 am
B-A isolation.mp3
Cheers
Robert
Robert, you might help me out. Im having a hard time with speech and drum separation when the drums are heard in the isolated center. How to get rid of that? Thanks
