Hello all,
Normally, I'm using Audacity on my desktop for music production. But sometimes I have to resort to Audacity (2.05, from the Software Manager) on my KDE Mint laptop. The problem is that it doesn't have Line/Mic In.
I tried to work around this with a 3D USB to Audio Model PD552 Line In adapter (see below)
that ought to operate through one of three USB ports on board. Only it doesn't.
The system recognizes the adapter. But Audacity not, so I suppose some settings should be changed. I have no idea where to start though, so some advice would be welcome.
Thanks very much in advance.
tnob
No line/mic In on laptop, so can't record in Audacity
Please state:
Please state:
Veerstryngh Thynner
- Quality Assurance
Re: No line/mic In on laptop, so can't record in Audacity
What exactly are you trying to record? That PD552 is a microphone input, not a line-in input. It's only suitable for low level signals from a computer microphone, not for strong line-level input.tnob wrote:Normally, I'm using Audacity on my desktop for music production. But sometimes I have to resort to Audacity (2.05, from the Software Manager) on my KDE Mint laptop. The problem is that it doesn't have Line/Mic In.
Audacity does not automatically recognise external inputs plugged in after Audacity was launched.tnob wrote:The system recognizes the adapter. But Audacity not, so I suppose some settings should be changed. I have no idea where to start though, so some advice would be welcome.
Try restarting Audacity or using Transport > Rescan Audio Devices.
Veerstryngh Thynner
Hi Gale,
Thank you for replying.
Anything else I might try...? Or some alternative for this PD552, perhaps?
tnob
On my Lenovo desktop, digitalizing my audio cassette archive (four-track as well as plain stereo) has been going well. A RCA-to-minijack audio cable between cassette player and desktop preamp - and Bob's your uncle! Without a hitch. But with a couple of hundred more tapes awaiting similar 'treatment', I thought of my laptop as a way of ramping up capacity. That, however, hasn't washed as smoothly yet, obviously...Gale wrote:
Attempted that several times. Transport >Rescan Audio Devices, that is. Nothing at all happening.Gale wrote:
tnob
- Quality Assurance
As I said, the PD552 is a microphone input. So it is not suitable for recording cassette tapes, even if it worked.
You can try these alternatives http://wiki.audacityteam.org/wiki/Recom ... Interfaces.
The UCA 202 usually works on Linux.
