new download page
Feedback and Reviews for Audacity 2.x
This board is ONLY for general feedback and discussion about Audacity 2.X.
If you require help, or think you have found a "bug", please post on the forum board relevant to your operating system.
Norm Mast
new download page
Post by Norm Mast » Sun Jun 28, 2015 3:29 am
I am doing a total download of the program here....hoping to clear up some audio issues I kept having. From the Audacity page when I click to download for my Windows XP OS I get taken to a differant page, with the name Foss Hub showing . A little uncomfortable seing this....is this the right page to be at?
OK, notice a new page info post above by Steve...where it does mention this Foss name...will go ahead and try that download.
Norm Mast
Re: new download page
Post by Norm Mast » Sun Jun 28, 2015 3:52 am
Oh great...downloaded it and now for some reason when I try to open it, I get this pop up window.
wxWidgets Fatal Error
This program uses Unicode and requires Windows NT/2000/XP
Program aborted.
My OS is Windows Xp....so now what?
Post by Gale Andrews » Sun Jun 28, 2015 4:58 pm
Norm Mast wrote:I am doing a total download of the program here....hoping to clear up some audio issues I kept having. From the Audacity page when I click to download for my Windows XP OS I get taken to a differant page, with the name Foss Hub showing . A little uncomfortable seing this....is this the right page to be at?
Yes. Fosshub is our download partner that hosts the Audacity downloads.
Post by Gale Andrews » Sun Jun 28, 2015 5:10 pm
Norm Mast wrote:Oh great...downloaded it and now for some reason when I try to open it, I get this pop up window.
Program aborted.
Windows XP is a security risk now that Microsoft no longer properly support it with patches. Please see Important information for Windows XP users.
If you feel you must use XP, Service Pack 3 is required for Audacity to run on XP 32-bit and Service Pack 2 for Audacity to run on XP 64-bit. Please see the links on http://audacityteam.org/download/windows#sysreq.
Make sure you are downloading http://www.fosshub.com/Audacity.html/au ... -2.1.0.exe. Download and save the installer, not run it without saving it. Where are you installing to?
Norm Mast
Post by Norm Mast » Mon Jun 29, 2015 2:02 am
OK..great..thanks Gale. My download location is into 'programs'...I may try these other things tonight that you speak of here. Sure would like to get Audacity back where I can use it here.
Post by Gale Andrews » Mon Jun 29, 2015 2:27 pm
Norm Mast wrote:My download location is into 'programs'...
If you install into Program Files and you are not logged in as administrator you must right-click the saved installer and choose to run it as administrator. Not doing so "should" not give you the error you mention, but just to cover bases.
cyrano
Post by cyrano » Mon Jun 29, 2015 3:15 pm
If I understand what you're doing there, it might just be the source of your problem. You should be downloading to a "downloads" folder in your documents folder or something like it. Then unzip the installer (if it's a .zip) and run the installer to install the application into the "programs" folder.
Norm Mast
Post by Norm Mast » Tue Jun 30, 2015 2:51 am
Ok...thanks Cyrano...I just tried this and I still get the problem I mentioned earlier. The Widgets fatal error issue. As far as I know I did download the SP3 as was menbtioned as well. I'll keep trying here..thanks all for the suggestions. Sooner or later I'll be back in shape.
Post by Gale Andrews » Tue Jun 30, 2015 4:08 am
To be sure it's not an issue with the installer or permissions, can you try the ZIP instead http://www.fosshub.com/Audacity.html/au ... -2.1.0.zip?
When you have downloaded the ZIP, use WinZip or right-click over the ZIP and choose "Extract All". Then just try double-clicking audacity.exe in the folder you extracted the ZIP into.
