Phantom Powered Mics dis-connecting me from internet
leslllll
Re: Phantom Powered Mics dis-connecting me from internet
Post by leslllll » Sun Jul 12, 2015 7:43 pm
ATT just said the U-verse box was old and needed to be replaced.
LesL
Post by kozikowski » Sun Jul 12, 2015 8:07 pm
I've since learned to reset everything by unplugging my ATT Uverse box and then plugging back in after about 10 minutes.
Still, a bad internet connection doesn't create that much damage. Maybe a bad power system was one of its failures. The servicing people would not have stopped to diagnose it. They would pull a couple of system checks and if it didn't pass instantly (no 10 minute wait), out the door.
Just so everything is OK now.
