On the equalization effect there is no Y axis labels for dB. There used to be before I upgraded. The x axis still has the frequency labels 60, 100, 200 Hz...
How do I turn on the dB Y axis labels again?
Equalization dB labels missing on Y axis
- Quality Assurance
Re: Equalization dB labels missing on Y axis
See the pink panel at the top of the page. Only download Audacity from http://audacityteam.org/download/windows/.
If Audacity 2.1.0 supplied by us has the problem, please provide a screenshot of the problem. Please see here for how to attach files: http://forum.audacityteam.org/viewtopic ... 49&t=64936.
- Quality Assurance
Please do not double post. I deleted your duplicate post.
