I am a Media guy, and I LOVE Raspberry Pi2 - So, I couldn't resist trying to try getting a DAW to work with Audacity on the Raspberry Pi.
I got Audacity installed and working, no problems there. I'm running UbuntuMATE on Raspberry Pi2, BTW - beautiful OS for RPi2.
Natually the RPi2 can't power my Focusrite Scarlett SOLO by itself, so I plugged it in through a Powered USB HUB, and it detected it immediately, plays desktop sounds out perfectly.
My issue comes when I try to record through Audacity - it records a HORRIBLE noise at FULL LEVEL - no matter if the mic is plugged in, or Phantom Power is turned on or not -
Without the SOLO connected, Audacity records clean (ZERO LEVEL) sound file. no noise -
So the noise is coming from the powered hub is my guess, but since RPi2 wont power the SOLO by itself, I can't test that theory.
Any thoughts?? Again, I realize this is probably not the right forum, or category for this question, but since I am using Audacity, on a RPi2 to try my little experiment, I thought I'd see what you thought.
Thanks for your time.
MedisGuy
